mhdrViewer HDRSee: an HDR image viewer
Description
operators HDRSee is a OpenGL/GLSL software that displays High Dynamic Range (HDR) and Low Dynamic Range (LDR) images. It is based on several libraries (e.g. glut, see below for full dependencies).
To display HDR images, HDRSee implements a few tone-mapping operators. Moreover, it is designed with a plugin mechanism that let developers add, as easily as possible, their own tone-mapping operator. All tone-mapping operations are done using Graphics Hardware through pixel shader operations.
The GUI currently used is nvWidgets but the next version will also support QT library.
The latest testing release is available at the INRIA GForge project page
Functionalities
Provided Tone-mapping operators
Dependencies
mhdrviewer uses and depends on the following librairies:
Current Developers
Feel free to contact the developers if you have some comments, bugs, futur request, insults ;) etc.
Authors
openGL       Qt
Valid XHTML 1.0 Strict CSS Valide !
